03-31-2022 12:03 PM
looking for g4 (g5) lte antenna preferably a directional one
i have a really crappy signal and in addition i nonstop connecting to a weaker and congested tower
all i can find are wifi antennas
which is the wrong frequency for my purpose as fare i know
wrong characteristics and not covering the hole required frequency range
3rd party antennas usually dont have TNC Male connectors and i would prefer not needing a bunch of adapters to get them connected but i am open to suggestions
any suggestion appreciated
Solved! Go to Solution.
03-31-2022 01:31 PM
03-31-2022 12:10 PM - edited 03-31-2022 12:37 PM
I suppose you are reffering to Cisco antennas? Where are you going to connect your antennas? Which kind of device?
03-31-2022 12:38 PM
device is c1111-4plteea
by "when" you probably mean where preferably outside (otherwise always :D)
i have got some extensions for the current ones (4G-AE010-R Extension)
but couldnt find a position with a reasonable signal with it inside the house
so i would like to try an external directed one
also i have the feling that after repositioning the antenna its not enough to wait a few seconds
to a change in signal strength but need to hard boot the device
(this may be provider specific as it keeps me on the current tower
although the new position could have a better signal on a different one
trying to position it by mowing it an inch to the left and wait 5-10 minutes for a reboot
is impracticable so a directed one would be really preffered)
03-31-2022 01:31 PM
ANT-4G-PNL-OUT-N= Antenna
ANT-4G-SR-OUT-TNC=
03-31-2022 01:51 PM
thx looks promising
04-04-2022 07:51 AM
Also remember you can have signal loss on the extension cables so best to use special low loss extension cables otherwise you risk negating any benefit of the external antenna.
