Low power alarms
u297863AG
Why am I getting low power alarms on APs connected via power injectors?
5 Replies 5
Stephen Rodriguez
what type of AP, aIOS or CUWN?
If aIOS:
power inline negotiation injector installed.
If CUWN
You can go in and check the power injector option in the AP config
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Its lightweight...and Power Injector State is already enabled.
change it to override, and see if that fixes it.
What type of AP and injector are you using?
HTH,
Steve
HTH,
Steve
Changing to override didn't clear the alarm. Its a 1252 AP and I'm not sure what type of injector is connected.
