Mac-address authentication per SSID
pbarman
Level 5
Level 5
Requirement is a user with macaddress1 is supposed to connect using SSID abc only. Second user with macaddress2 should connect using SSID xyz only.
If user with macaddress1 ever tries to connect using SSID xyz, he should NOT be given access to the network.
Is it possible to configure this, if so, how?
Thanks for any info provided.
PB
umedryk
Level 5
Level 5
As far as I know, there is no option to configure this...
