Machine Authentication
c.fuller
Level 4
Level 4
Currently my clients (XP/SP2/latest MS hotfix) are logging onto the wireless network using WPA/TKIP/PEAP. They are configured for both machine authentication (needed to download correct profile from server) and user authentication. I notice that for each logon there are multiple machine authentications showing up in the ACS (anywhere from 3 - 15) This varies and is random. Anyone know why I am seeing this many machine authentications and if there is something I can do to eliminate them? My clients are not consistently logging onto the network and I am thinking this may have something to do with it. I do not see any errors on AP or ACS when clients fail.
rsumpter
Level 3
Level 3
We have the same config. I don't see more then one machine authentication before the user logs in.....hmmmm.
So you only ever see one machine authentication.
Do you use the windows wireless client software for client configuration? I do.
WPA
TKIP
PEAP
Check authenticate as computer when info is available
Have acs server and certificate authority entered
Enable fast reconnect (client and server)
Automatically use windows login information.
I have the autologon setup so once the client boots up the information is passed to the wireless client to the radius server.
How is the SSID configured on the AP?
I have the TKIP cipher selected for encryption
I have OPEN with EAP, NETWORK EAP selected
I select KEY Exchange mandatory, CCKM and WPA.
Any information on your particular setup would be appreciated.
I have a similar setup. On the failure log there are a lot of "NAS duplicated authentication attempt"
I have not had any luck trying to track this down.
