Manage C9120AXI-F using AIR-CT5520-K9
bezeddin
Hi All,
Can we manage C9120AXI-F using AIR-CT5520-K9 ?
Budi
5 Replies 5
Leo Laohoo
As long as the controller is running the correct supported firmware (8.10.X.X).
Thanks @Leo Laohoo for the insight
as per checking on CCM the only software release is 8.2
can we upgrade later using SNTC service ?
Budi
Any software version less than 8.10 the AP C9120AXI will not register.
WLC must be running 8.10.X.X -- I cannot be more clear than that.
If the controller "has to" be on 8.2.X.X then convert, at least, one 9130ax into Mobility Express.  All the other 9130ax will be controlled by the ME.
marce1000
 - Go here for compatibility info's :
            https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
 M.
