08-18-2011 05:03 AM - edited 07-03-2021 08:35 PM
Hi there
I am interested if there is a possibility to allow an user to login only once to a specific WLAN. I know the WLC feature "Max Concurrent Logins for a user name", but this is a global setting and I need it to be only applied to a specific WLAN.
Is there a RADIUS attribute which will help my to enforce this? If yes, how will this work:
1. Will the logged in WLAN session be disassociated and the new one is possible to login
or
2. Will the second login attempt be blocked
Thanks a lot and best regards
Dominic
08-18-2011 07:06 AM
There is an attribute in ACS that checks the concurrent logins. If I'm remembering correctly, the second session would be denied access.
So for example, user john.smith logins on his PC/MBP, this will pass and he'll have access. Now he tries to access via his iPad, this will fail, as it's the second connection.
In the WLC, under the RADIUS config, there is a format for the message. You'd need to set this to ap-mac-ssid (or the similar setting) so that the WLC sends the SSID attribute to match on.
HTH,
Steve
08-19-2011 12:59 AM
Hi Stephen
Thanks for your answer. I am gonna search this attribute on ACS and will post my solution here afterwards.
Dominic
08-22-2011 11:36 PM
As seen in the ACS 5.2 Release Notes:
The following features are not supported in ACS 5.2:
-Support for defining the maximum number of simultaneous sessions for a user or user group.
So there is no such feature available in 5.2, hopefully they implement it in 5.3.
08-27-2011 07:07 PM
Does anyone know if the 5.3 release is still on track for mid-September?
