Max retransmission to AP CW9166I-ROW
husseinrhebi
Beginner
Beginner
I have Cisco Catalyst 9800-L Wireless Controller model and CW9166I-ROW  AP  running version  17.9.4
 The Issue : Max retransmissions to AP
AP automatic disjoin to WLC and automatic join aging
11 Replies 11
Leo Laohoo
What is the country code configured for the ROW?
he country code for ROW is Libya (LY). I know that Libya does not support 6 GHz radio, but it should work on 5 GHz or 2.4 GHz.
 - Have a checkup of the 9800-L configuration with the CLI command show tech wireless ; feed the output into
        Wireless Config Analyzer
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Please find attached the implementation of 'show tech wireless' in the Wireless Configuration Analyzer.
eglinsky2012
Participant
Participant
How is the wiring, are there any errors on the switch port or AP interface? Is there a WAN link on the wired network between the AP and the WLC (IPSEC, etc.)?
No, there are no errors on the switch port to the AP, and there is no WAN link.
marce1000
 - Following up on results from WirelessAnalyzer : set valid time , time zone and configure valid and working NTP server (service) on the  9800-L controller ,
 M.
After adjusting the time, the problem is still the same
Rich R
Make sure you have the 17.9.4 APSPs and SMUs installed.
https://software.cisco.com/download/home/286323430/type/286308587/release/17.9.4
https://software.cisco.com/download/home/286323430/type/286325254/release/17.9.4
If you still see the problem open a TAC case for TAC to capture all the relevant debugs, radioactive traces and packet captures.
ammahend
lot of good suggestions, you can also start with some basic KPI check for APs and see how things look like, may be we find something unusual.
  • Check for AP reloads or capwap restarts. Identify APs with lower "AP Up Time" -->reload or lower "Association Up Time"--> capwap restart
show ap uptime | ex ____([0-9])+ day
     Note : focus on APs reloaded or restarted within 1 day
  • Check for AP crashes
show ap crash
  •  Check for highest number of events or unexpected events of AP session termination
show wireless stats ap session termination
  • Check for disconnect reasons and time of disconnections
show wireless stats ap history | i Disjoined
  • Check for APs with misconfigured tags
show ap tag summary | i Yes
-hope this helps-
thanks for your support
