MESH Design & installation question
Using  MESH AP 1552E , for designing MESH network and determining parent ,child APs , i want to configure all APs with "Preferred Parent Selection" configuration to make sure that each mesh tree will not exceed 3 MAPs per RAP.
How can i check SNR between Parent-child AP while installation to make sure that SNR for each Backhaul link will be more than 20 db
Is there any CLI in the AP to check this SNR received value from its configured neighbor ?
Knowing that i am using omni directional antenna
0 Replies 0
