I have been searching through the cisco docs for a while and i just cant seem to find this info. Can I run aironet 1600's with my wism running 7.0.116? Also, could I run my 1130 series ap's with a wism2? Basically, what is the minimum code level for a lightweight 1600, and what is the maximum code level for a lightweight 1130?
Solved! Go to Solution.
For the 1600 to work you need to be running 7.4 code. Per the release notes 7.4 will support both AP models you have
http://www.cisco.com/en/US/partner/docs/wireless/controller/release/notes/crn74.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
awesome, thanks!
Hope you are doing good,
I am totally agree with Stephen.
For both AP 1600 and 1130 you need to be running 7.4 code.
For more reference you can visit the below link
