03-19-2002 01:50 PM - edited 07-04-2021 11:02 PM
I have a problem with my new install of ACU v5.01 to work with my Cisco 350 Series wireless adaptor. When I start the program it warns me that I will not have full functionality without updating the NDIS driver for my system. Unfortunately I am not at all sure how to do that and haven't had any luck finding answers at microsoft.com. I am running Windows 2000 with SP2 any sugjestions would be appretiated.
03-19-2002 02:45 PM
The NDIS driver refers to the actual Windows2000 driver used for the client card.
The updated NDIS (client card) driver is available from CCO in the same place as the updated ACU software.
Whenever you update ACU, you should check if there's a new NDIS driver too.
03-19-2002 02:47 PM
What version of firmware ae you running on that card? i ran into that problem on a win 98 machine. i loaded the 4.25.23 firmware and that seemed to do the trick.
