Mitigating noise and vibration interference
jorgelorenzo
I have a Cisco AP1142 Standalone AP at two of my locations. However both of these are being rendered useless every night and require a reeboot to correct the issue, because of the high level of noise and vibrations coming from the extremly loud bands that play there, Someone sugested an enclosure stuffed with insulation but Im afriad of overheating the AP. Is there anyone that has successfully resolved this type of issue? Any help would be greatly appreciated.
TIA
Justin Kurynny
Level 4
Level 4
Jorge,
Can you elaborate on how sound and vibration are causing an issue with the APs that only a software reload can fix? I'm having trouble linking cause and effect here.
Justin
Leo Laohoo
I have never heard of this issue before.
Can you please post the output to the following commands:
1.  sh version;
2.  dir; and
3.  sh log
