Mobility Express rogue auto-containment
jmprats
Level 4
Level 4
Rogue auto-containment may have legal consequences, so it should be clear whether or not you are enabling it.
I think Mobility Express is not clear about auto-containment. I just found the "Rogue Policies" option in the Best Practices menu. This option sets the rogue detection security level to high.
Does this option enable auto-containment? What will it contain automatically?
If this option is not enabled, can i be sure that auto-containment is disabled?
I think the GUI should be clearer on this subject.
0 Replies 0
