07-06-2020 09:10 PM - edited 07-05-2021 12:15 PM
Hi Team,
I am trying to form a mobility tunnel between l between WLC9800 - CATOS and WLC3504 - AireOS . However, unable to do so.
I am following below steps to achieve the same :
Control and Data Path is down at the moment . Both the WLCs are in different zones. FW rule is open as well between them . I can ping it which means they are reachable as well however unable to form the tunnel between them.
Happy to discuss this further.
Dayesh
07-06-2020 09:30 PM
07-06-2020 10:20 PM
Thanks Scott.
Yes AireOS is on the supported version compatible version i.e 8.5.164.0 and firewalls rules are open too for that port.
Tried running mping and eping from WLC3504 , correct FW rules are getting hits.
Is there a command that I am missing on WLC9800 ?
07-06-2020 11:08 PM
07-07-2020 07:01 AM
07-07-2020 05:43 PM - edited 07-07-2020 06:58 PM
Apologies . Yeah its running on( C9800_IOSXE-K9), Version 16.12.3 and AireOS on 8.5.164.0
Following are the debug logs :
*mmListenFsm: Jul 07 16:24:58.950: Client initiating connection on 172.21.160.13:16666 <-> 172.23.20.15:16666
*mmListenFsm: Jul 07 16:24:58.950: Sending packet to 172.23.20.15:16666
*osapiBsnTimer: Jul 07 16:25:05.705: Tearing down link 172.21.160.13:16666 <-> 172.23.20.15:16666 due to timeout
*osapiBsnTimer: Jul 07 16:25:05.705: Disconnecting link 172.21.160.13:16666 <-> 172.23.20.15:16666 (dtls2_timer_handler)
*osapiBsnTimer: Jul 07 16:25:05.705: Nothing to send on link 172.21.160.13:16666 <-> 172.23.20.15:16666
*osapiBsnTimer: Jul 07 16:25:05.705: Crypto keys removed from DTLS engine.
*osapiBsnTimer: Jul 07 16:25:05.705: mm_dtls2_callback: Connection with 172.23.20.15:16666 is terminated
07-07-2020 06:57 PM
Any further suggestions will be appreciated?
Packet capture also looks fine between the two WLCs...
07-07-2020 09:27 PM
07-08-2020 01:01 AM
07-08-2020 01:42 AM
Hi Scott ,
I have followed the below step from the document as well and enabled secure mobility on AireOS.
On the 9800 WLC, control plane encryption is always enabled, which means that you need to have secure mobility enabled on the AireOS side.However, data link encryption is optional. If you enable it on the 9800 side, you will need to enable it on AireOS with config mobility group member data-dtls <mac-add Cat9800> enable.
Data link encryption has been disabled on both the ends.
07-08-2020 01:59 AM
Hi Rudling,
Encryption is disabled at both the end . Also , the port below in the mobility summary is 16666 therefore I think negotiation over 16666 is correct.
Note: Port 16667 indicates secure-mode (encryption). Port 16666 indicates non secure-mode (no encryption).
(Cisco Controller) >show mobility summary
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... DEF-Mobility
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x676d
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address IP Address Group Name Multicast IP Status
4c:e1:76:c1:d1:ab 172.23.20.15 ABC-Mobility 0.0.0.0 Control Path Down
70:18:a7:c8:1c:d0 172.21.160.13 DEF-Mobility 0.0.0.0 Up
Please share your thoughts.
07-08-2020 02:07 AM
And I continue to see the same debug..
*mmListenFsm: Jul 08 01:09:29.925: Client initiating connection on 172.21.160.13:16666 <-> 172.23.20.15:16666
*mmListenFsm: Jul 08 01:09:29.926: Sending packet to 172.23.20.15:16666
*osapiBsnTimer: Jul 08 01:09:36.843: Tearing down link 172.21.160.13:16666 <-> 172.23.20.15:16666 due to timeout
*osapiBsnTimer: Jul 08 01:09:36.843: Disconnecting link 172.21.160.13:16666 <-> 172.23.20.15:16666 (dtls2_timer_handler)
*osapiBsnTimer: Jul 08 01:09:36.843: Nothing to send on link 172.21.160.13:16666 <-> 172.23.20.15:16666
*osapiBsnTimer: Jul 08 01:09:36.843: Crypto keys removed from DTLS engine.
*mmMobility: Jul 08 01:09:36.843: DTLS Action Result message received
*osapiBsnTimer: Jul 08 01:09:36.843: mm_dtls2_db_status_down:933 Connections status down for entry 172.23.20.15:16666
*osapiBsnTimer: Jul 08 01:09:36.843: mm_dtls2_callback: DTLS Connection with 172.23.20.15:16666 is terminated,Sending update msg to mobility HB
07-08-2020 03:02 AM
07-10-2020 04:37 AM
07-10-2020 02:27 PM
Hi Scott,
I raised a TAC with Cisco . The command to enable the secure mobility didn't work on the local mobility group in AireOS. Also , deleting the local mobility group in AireOS isn't allowed using the delete keyword.
It kept giving following error
(Cisco Controller) >config mobility group member delete 70:18:b7:18:12:d0
Cannot delete system mac
(Cisco Controller) >config mobility group member add 70:18:b7:18:12:d0 172.21.160.13 ABCD-Mobility encrypt enable
Mobility group with management IP address is already configured.
I've asked Cisco to reproduce it in the Lab and they are also recommending version upgrade from 8.5.164 to 8.8.111 which is misleading from the Cisco documents.
Awaiting Cisco's feedback.
Thanks.
