01-07-2018 04:42 AM - edited 07-05-2021 08:03 AM
Hi All,
We are using WLC 5508, Version 8.1.
I identified Bit torrent and FTP traffic outbound from an Guest-Wifi
network & lots of video streaming.
Is there any way to monitor the bandwidth & if we can get any email alert for the same by setting threshold.
Deepak
Solved! Go to Solution.
01-10-2018 02:14 AM
HI,
There is no such option in WLC however to see the traffic and data rate real time you can use the some other third party applications like cacti, solarwind etc they are very efficient tools which can tell you how much traffic has been segregated over your WLC port.
Cacti interface
for email notification you can use the Cisco Prime Infrastructure NMS which is best tool to receives notification and alerts also you can see the WLC port traffic on Cisco Prime
Cisco Prime Interface
01-07-2018 05:02 AM
01-08-2018 02:47 AM
Hi Scott,
Thanks for your help.
Client is looking for more of monitoring,they want to block the user after monitoring it.
Deepak
01-08-2018 04:22 AM
01-10-2018 02:14 AM
HI,
Cacti interface
