Motorola APX 6000 wireless issue
ammahend
Has anyone worked with Motorola APX6000, they seem extremely sensitive and even slight movement is effecting the WiFi signal strength, which is causing their smart connect service to disconnect hence service disruption for first responders in some areas where they rely on WiFi,
these are old model that operate on 2.4 only, I couldn’t find their antenna receive sensitively information any where. In the attachment you will see how slightest of movement effects the WiFi signal
any help is appreciated.
-hope this helps-
0 Replies 0
