Motorola Handscanner loosing connection to AS400 application
Willem de Groot
Hi All
I Updated the 5508 from 7.0.230 to 7.4.100 and made it a cluster.
Sinse the Update the handscanners loose the connection to the AS400 Application.
Where to start troubleshooting?
I did a debug client, I see the client is roaming but I can not say if there is a relation between roaming and loosing connection to the application.
Please help.
20 Replies 20
I will try to get more info. I think Motorola understands they have an issue with the current driver but initially was blaming the wireless. Let me get the info from my peer.
-Scott
Scott Fella
Yahya,
Here is the TAC case number SR 625141303
-Scott
Scott,
thanks alot.
it was solved by WPA/TKIP and motorola support.
No problem... maybe the handheld device should have a section on using WPA/TKIP so others don't run into the same issue.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi all
the problem is solved.
first what we did (thanks to Scott and Yahya) , change SSID to WPA /TKIP only.
Second changed the Scanners to CAM Mode = constant awake mode.
Glad to help out
-Scott
