Mounting Information AP-Bracket-2 and Air-Ant-2566P4W-R
sniff
for mounting preparation I need information about
hole-size and hole pitch (position / distance between holes)
for AP-Bracket-2 and ANT-2566P4W.
I can't find this information (installation guides).
Sven
Scott Fella
The hole size is mentioned in the docs, but you will not find the drawing with the hole spacing anywhere. You would need one of each as a template to be 100% sure.
-Scott
