MSE 7.4 Base Location Services and Context Aware Licences?
Hi! I have a question for MSE Base Location Services and Context Aware Licences. Do I need to add Base Location Services and Context Aware Licences in L-MSE-PAK or just enough Base Location Services Licences? What is the difference in these licenses?
I know that the Base Location Services license is determined by the number of access points, and Context Aware license is determined by the number of devices.
Please help me with this issue.
Jacob Snyder
Level 5
Level 5
In 7.4 the context licenses are no longer used. You need the base location license.
OK, for example, a customer bought a Context Aware license. Can he activate it in MSE 7.4 or need to install MSE 7.3 with Context Aware license and then upgrade to MSE 7.4?
Licensing is different when you go to v7.4, so yes you can upgrade, but the license changes and that is what you have to understand. Please read this PDF as it will explain how the licensing changes.
http://www.cisco.com/en/US/prod/collateral/wireless/ps9733/ps9742/qa_c67-726505.pdf
-Scott
