Highlighted
Enthusiast
Naming and addressing AP's with WLSE.
I've setup a WLSE to auto-configure a new AP (set opts 66 & 67 in the DHCP server) so that the WLSE detects and manages a new AP when it's first powered on. The only thing I haven't managed to make it do is assign a unique name and the correct ststic IP address to the AP's, I have to do this part manually.
Is there any way this can be built into the WLSE templates?
1 REPLY 1
Highlighted
Beginner
Since the templates are designed for mass deployment there is not a value for hostname and IP address under the predefined options. You can define a template for a specific device and enter these commands in the custom values. Remember that the custom values are not validated by wlse and syntax is not checked.
Content for Community-Ad
