Need access to a wireless access point
SaadMughal
Hi All,
I have 4 Cisco AIR-SAP16021-AK9 access points. I dont have info on the creds to access the web interface nor know the ip addresses for the access points. I simply have access to connect to the SSID that is configured on it. I tried resetting one of the APs to try and reconfigure it, however can't seem to find the ip address after resetting. Running a network scan doesnt provide me with anything. I saw that installing IPSU software I can enter in the MAC address and find the ip, but cannot find anywhere to install IPSU.
I dont have the cable to connect to the console of the APs. Please help.
Thanks in advance.
Rasika Nayanajith
What switch these APs plugged into ? if it is a Cisco switch, you can issue "show cdp nei detail" and that should tell you IP addresses of these AP.
Rasika
*** Pls rate all useful responses ***
