12-26-2013 07:57 AM - edited 07-04-2021 11:51 PM
I just started working for a company that has no documentation for the network. What i am trying to do is setup 7925 wireless phone and the wireless system uses a 5508. The WLAN for the phones has a pre shared key but it just shows 3 asterisks. I can't find anywhere in the CLI either to show me in plain text. Can someone tell me how I can retrieve it?
Solved! Go to Solution.
12-26-2013 09:11 AM
No you don't... if you have to change the PSK, then you will have to change it on the WLC and then on each phone. You might want to take a look at this bulk utility.
http://www.cisco.com/web/software/282074239/14006/792xBD.1-0-Readme.pdf
Scott
Help out other by using the rating system and marking answered questions as "Answered"
12-26-2013 08:01 AM
You will not be able to see the pre-shared key if you are using WPA/WAP2 w/psk. If you are using WEP, you can.
Scott
12-26-2013 08:03 AM
To view the wep key
Scott
12-26-2013 08:40 AM
In viewing the WLAN security it is WPA+WPA2. Do I have any other options other than changing it and going to each phone currently using it to put in the new PSK?
12-26-2013 09:11 AM
Scott
12-26-2013 10:13 AM
Thanks for the information. I went ahead and just created another WLAN until I can track down the PSK. Great info Scott.
