Need your help on Creating an ACLs on Wireless LAN Controller 4400
huyen01thpm
I have tried to create and apply an Access Control List on my Wireless Lan Controller but it can't work.
My requirement is all the Guests that use Mynetwork by Wifi, they just:
  • using the WEB sevices only.
  • chating by Yahoo only.
My configuration as below:
Any help and suggestions on that are many thanks from my heart.
Nguyen Huyen.
tfraij
Hello Nguye,
can you please make sure of the following:
1) have the ACL been applied to an interface or WLAN
to check go to controller ->> interfaces ->> name of interface assigned to geust network ->> ACL....
also under WLAN ->> advance , override ACL.
2) if there are any proxy settings ,please make sure to allow it in the ACL.
Kind regards
Talal
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
Hello Talal,
the ACL have been applied on Interface only. Let I try to apply both of them and see.
have any ideas else?
Thanks Talal so much!
hello Huyen,
also please make sure that the clients (WLAN) connect to that Specific interface... make sure there are no AP groups configured that is overwriting the WLAN settings (interaface) ....
Kind regards
Talal
