04-25-2013 12:27 AM - edited 07-03-2021 11:58 PM
Hello, since few weeks i configure my APs on the new WLC5508, and then, the lights are off on the AP, is it normal? however they seems to work fine.
What does this light means?
FW version: 7.0.22
Is it important?
Tx,
B
04-25-2013 04:47 AM
On the cli of the WLC, issue a config ap led-state enable. The AP's might of been defaulted to disable the led.
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/lwap/config_lwap_chapter_011010.html#d17301e16a1635
04-25-2013 02:24 PM
Observe the access point LED.
a.
When you power up the access point, it begins a power-up sequence that you can verify by observing the access point LED. If the power-up sequence is successful, the discovery and join process begins. During this process, the LED blinks sequentially green, red, and off. When the access point has joined a controller, the LED is green if no clients are associated or blue if one or more clients are associated.
b.
If the LED is not on, the access point is most likely not receiving power.
c.
If the LED blinks sequentially for more than 5 minutes, the access point is unable to find its primary, secondary, and tertiary Cisco wireless LAN controller.
