05-01-2016 06:34 PM - edited 07-05-2021 04:59 AM
Hello. I have a linksys WRT54GH access point. The problem is that it is showing SSID to some devices and not to others. Devices which can see the SSID can't connect to the network. I have tried a factory reset but no help. Can I do something about it? Or I should throw it and buy a new one?
05-01-2016 08:19 PM
As per the below document this is only operate in 2.4GHz band & supports 802.11b/g standards. (refer appendix B in page 24)
http://www.sysnetcenter.com/documents/linksys_wrt54gh_ug.pdf
So make sure your end client supports connectivity in 2.4GHz radio band.
Rasika
05-01-2016 08:56 PM
I have checked the specifications of all clients. All support 802.11 b/g/n and 2.4 GHz/ 5 GHz both.
I have used the router in the past
