Not Able ping Management port for 5520
in core switch in create vlan 94 int vllan 94 192.168.50.254
and assign wlc management port 192.168.50.252
i make untagged vlan 94 at time WLC installation
with service port i can access WLC GUI
with Management port i am not able to login with out switch also when i directly connect to lan Port also
3 Accepted Solutions
Sandeep Choudhary
paste the swicthport config where WLC is connected!!!
Did you configured native vlan on switchport ?
I had this same issue, best is the remove the native vlan on the trunk and have the wlc tag the vlan. This is what I have been doing with the controllers without issue.
Either one end you have to Tag the VLAN. Do only on the WLC via taking the console of it.
If you do on the WLC End, switch end its not required
Its good to enable the CIMC of the WLC, So that you can take the console of the WLC in case of any issue 5520 WLC CIMC Configuration
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
19 Replies 19
Sandeep Choudhary
Configure Native VLAN 94 on the switch port. At-least on one end, you have to tag VLAN.
Its recommended to tag the VLAN on WLC end.
management 1 94 192.168.50.252 Static Yes N/A
redundancy-management 1 94 0.0.0.0 Static No N/A
these port are already tagged then telling again tagged via cli
please tell how can do this
Haydn Andrews
please post:
Switch port/s config
From WLC
show interface summary
show interface detail management
show port summary
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Thanks support Team ,
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
redundancy-port - untagged 0.0.0.0 Static No N/A
service-port N/A N/A 0.0.0.0 DHCP No N/A
virtual N/A N/A 1.1.1.1 Static No N/A
after that i assign ip  to service Port  i am able to access wlc via gui
but for Mgmt LAN 1 is not wking with and without switch
for core switch
int gi1/1
switchport mode trunk
switchport trunk allowed vlan all
and one end of the cable is is connected to lan port of ucs wlc
At that installation time of wlc
0: untagged : 94
Tag the VLAN 94 on the WLC management interface. The issue will get resolved.
i will do again from scratch again
can i make  command line to make tagged for mgmt interface in wlc
if am doing from scratch at time installation 0:untagged =vlan number or 0
then switch side
vlan 94
int vl 94
ip add
int g1/1
switch port mode trunk
switchport trunk native vlan 94
please correct if any thing is missing
i also do not configure CIMIC in UCS Server
i need CIMIC ip add i should use different subnet
it is optional or mandatary to configure in cimic ip add for 5520 wlc
please advice
sw
in WLC 0:untagged 0
this command in need apply
or any other command
How can i do tagged for managment vlan
at time begining i make tagged for example 0:untagged=94
it already tagged managment vlan 94
please correct me i am wrong
Still you are not able to access it ?
Can you paste the current switch configuration?
these setting applied previously also  tommorow i am going site need to make wlc gui
please advice
There are two controller and core switch
in core i will create vlan 94
int vl94
ip addd
 and int g1/1
in the wlc
i had made at installation 0:untagged=94
i assume that my management vlan is tagged
i am confusion these tagging of management vlan
experts please advice
as i am not able to ping the controller
