Not able to connect Air-CAP2702 to WLC 5508
nasersayar1
Beginner
Beginner
Dear All,
I will much appreciate to let me know how to connect the Access point AIR-CAP2702 to the wireless controller 5508 I try a lot but the access point does not appear on the wireless controller.
many thanks and best regards,
Naser Ahmad
23 Replies 23
Leo Laohoo
VIP Community Legend VIP Community Legend
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version; and
4.  AP:  sh ip interface brief
Thanks Leo,
1.  WLC:  sh sysinfo; Cisco 5500 series wireless LAN controller
2.  WLC:  sh time; Afghanistan Time
3.  AP:  sh version; and 7.6.100.0
4.  AP:  sh ip interface brief gigabit interface
Leo Laohoo
The response supplied is NOT helpful at all.
I recommend you provide the COMPLETE output to the commands requested because we know what to look for.
Dear Leo,
thanks and sorry for misunderstanding here is attached all the info.
Naser
Leo Laohoo
Product Version.................................. 7.6.100.0
WLC firmware 7.6.100.X does NOT support AP2702.  You will need to upgrade WLC firmware to a minimum of 7.6.120.X for AP2702 support.  My recommendation is to upgrade to 7.6.130.X instead (due to stability issues).
Product/Model Number                 : AIR-CAP2702E-A-K9
However, upgrading the firmware won't solve the issue as the AP will still not join the controller because the AP has the wrong regulatory domain.  Read THIS.
The WLC is configured for Pakistan but the AP has the incorrect Regulatory Domain of "-C".
Thanks where to get the new firmware 7.6.130.x ?
I saw the list I register the WLC to PK as I couldn't find Afghanistan and for your info we purchased this through US. what is your recommendations for the selection of the country.
Leo Laohoo
The latest firmware version 7.6.130.X can be found HERE.
I cannot remark on the regulatory domain because this is purely political.  But as far as I'm aware, even if you enable the country of Pakistan in the controller the AP won't join.  The AP will join if you enable US on the controller.  But be aware that this might contravene telecommunication laws in the country of Afghanistan.
Just to add, you need to use the appropriate ap model for the country You will be installing the access point. The ap that you have is only for the U.S. And most likely you might get into trouble if Afghanistan doesn't allow the same channels and or power. Get the correct ap for the country is what I would suggest.
-Scott
-Scott
What if you make this change, but all other changes cause the APs to register to other WLCs - never the priority WLC in the HA list? REF the issue below:
https://supportforums.cisco.com/discussion/12522301/2702i-e-ap-cannot-join-wlc-after-changing-mode-flexconnect
Erase fixes and allows registration, but all resets after cause to jump to a different WLC....
I upgraded the Firmware to 7.6.130.0 and changed the county of WLC to US but still I am unable to get connected to AP.
Leo Laohoo
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
Thanks here is the latest updated files,
Leo Laohoo
BVI1                       unassigned      YES DHCP   up                    up
The AP does not have a valid IP address so it's obvious that the AP cannot join the controller.
Is DHCP Option 43 configured?
No but I want to assign a static IP for the AP could you let me know how to do it?
Recognize Your Peers
