Not able to connect Air-CAP2702 to WLC 5508
nasersayar1
Dear All,
I will much appreciate to let me know how to connect the Access point AIR-CAP2702 to the wireless controller 5508 I try a lot but the access point does not appear on the wireless controller.
many thanks and best regards,
Naser Ahmad
23 Replies 23
Console into the AP and in enable mode, enter the following:
1.  capwap ap ip address <IP Address> <Subnet mask>;
2.  capwap ap controller ip address <Management IP address of the WLC>
Thanks Leo,
Now the AP is reg to the WLC but I do have another question we are using RADIUS server in our AD server and all clients MAC add is registered how I can configure the WLC to use that RADIUS server and Authenticate with the RADIUS server.
regards,
Naser
Kindly read this:  Configuring RADIUS
Thanks I read that but couldn't find anything that weather this WLC is compatible with Microsoft Radius server or not?
It is compatible with MS.
But I couldn't find configuration steps on the document that you sent can you tell me the steps to configure it.
thanks could you send me this for 5508 model as it is completely different than this.
regards,
Just do a search on Google for this. There are many examples on how to do this with the WLC's.
-Scott
-Scott
