Showing results forĀ
Search instead forĀ
Did you mean:Ā
Not able to login to AIR-AP2802I via https
samsita
Hello Team,
I am installing new AIR-APs 2802I in my office, I have uploaded ios AIR-AP2800-K9-ME-8-3-143-0.tar, routing and autosetup done,I am able to ping new AP, and login via ssh, but unable via https. I have turn on the https (
config network secureweb
), however https should be enabled by default. But https doesnt work. I have used multiple web browser, but result is the same - not found. What should be done to resolve this issue? I want to login via https.
Please help me if you can.
Thanks a lot.
luis_cordova
Hi @samsita ,
You could check if you can access the web interface with http.
If you can access, you can follow this guide to enable entry by https:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15_2_4_JB/configuration/guide/scg15-2-4-Book/scg15-2-4-chap2-gui.html#13099
