Optimum CMX Presense RSSI Threshold Settings
DAVID
Level 3
Level 3
In the site settings in CMX for a site, is the Signal Strength Threshold settings measured from an access point?  I have retail stores, some inside malls and others located in strip malls. I'm trying to adjust the rssi so that CMX truly counts a visitor as someone that enters the store and it not someone who is standing out in the mall from the store or sitting in a car in the parking lot.
I want CMX to count you as a visitor only if you enter the store and stay for at least 8 minutes.
Yuk Tun Fong
The Signal Strength Threshold should be measured by the AP from a client device.
