04-17-2009 07:08 AM - edited 07-03-2021 05:27 PM
I'm looking for an outdoor enclosure that will hold a 1242 AP, can handle the fittings to pass-through the antenna connection (sealed connectors with pigtails so that we can use patch antennas), and has a cooling fan. The fan must be 48v DC powered as I cannot run AC power out to the AP.
I like the Tessco (link below), but it is AC powered, and they won't do a 48v DC fan version for the low quantity we want to buy (we don't need a heater).
04-17-2009 11:03 AM
Try these guys:
http://www.l-com.com/productfamily.aspx?id=6017
and / or google "nema weatherproof wireless"
Good Luck
Scott
04-17-2009 11:53 AM
I use Sparco since they can customize the enclosure to what you need. Ask for Nathan he can maybe come up with a DC power option.
http://www.sparcotech.com/PDG-EnclosureSelector.html
