03-23-2005 06:27 AM - edited 07-04-2021 10:36 AM
Hi all
I have a WPA / PEAP network which runs fine, machines authenticate pre login fine then the user.
The issue is when the laptops go into standby, they loose the wireless link and machine re-authentication fails with the ACS message "SSL handshake failure"
Once they logoff/on machine authentication works fine.
I am using Dell lattitude laptops with centrino with XP and SP2.
It sounds like a microsoft issue, but has anyone else had this problem, and if so how have you sorted it.
Thanks in advance
Colin
04-18-2005 12:30 AM
I have the same problem, then you have to log off and login again.
waiting for solution.
Aamir
04-27-2005 04:35 AM
Well, we are running the same "solution" and it works just fine here..
Works just fine when the laptop goes in standby.
We are running xpsp2 on a hp6220laptop with WPA/PEAP auth.
04-28-2005 07:26 AM
Are you using PEAP,MS-CHAP.. or PEAP,GTC?
Because this is working just fine with GTC
Microsoft has a fix KB885453 adressing XP-SP2 problems with 3.party AAA servers like ACS.
04-28-2005 10:42 AM
Also take a look at these hotfixes. They solved some other issues with MS-Chapv2 auths. Not sure it GTC is affected by the sp2 change with radius. But check it out non-the-less. Hope this helps.
