08-21-2007 10:04 AM - edited 07-03-2021 02:30 PM
Simple question for you experts, i have setup peap in a lab enviroment but have not managed to put a windows server together for the MSCHAP part, question if a client authenticates with a cert and i dont have the link to windows datbase configured via the remote agent will the acs default and look into its internal user directory to autheticate the user, obviousley this is only for a test enviroment.
Solved! Go to Solution.
08-21-2007 10:41 AM
Hi ,
Yes, if you don't have any ext database configured, acs will (by default) look for user in its internal database.
~JG
08-21-2007 10:41 AM
Hi ,
~JG
