PI 1.2 Heat Maps are offset
dporod
Beginner
Beginner
Hi, after upgrading to PI 1.2 the heat maps are offset. Worked fine before and also I've noticed that some of my maps do look fine until I reposition an AP on it, then all AP heat maps on that map will then be offset.
Has anyone else see this issue?
4 REPLIES 4
M. Wisely
Enthusiast
Enthusiast
You're not alone, we're seeing this as well. I guess it's just another bug, have you contacted TAC yet?
Interesting... I haven't ran into that issue during any of my NCS to PI upgrades. Looking forward to seeing what TAC says.
-Scott
dporod
Beginner
Beginner
I tried something from another post and it seems to work.
While in a map with the issue, try "Recompute RF Prediction.." from the pulldown menu. Seems to fix the offset.
ieee1284c
Beginner
Beginner
I run into this all the time in Prime.  Here's a brand new map with 2602 7.4 code AP's freshly placed.  I have to recompute all of my new maps and some of my old ones.  Would be nice if there was a global command to do that, or if the issue could be resolved.
