08-29-2016 11:34 AM - edited 07-05-2021 05:44 AM
Hi all,
I´m planning this layout with Cisco 2504 controller and 1832 AP´s:
The WLANs should be switched locally with FlexConnect local switching. I have read a lot of documentations about FlexConnect but I´m not sure which interfaces I need on the controller.
In my example: Do I need all the vlans (11-13,21-23) configured as Interfaces on the controller?
Can anybody give me a configuration example for a wlan configured as Flexconnect local switching?
Thank you all!
08-29-2016 11:41 AM
You don't need to create virtual interfaces on your wlc with all local vlans.
However, you have to create the vlan mapping on your wlan configuration.
There are several documentations done. Let me paste 2 of them. The 1st one is clear and simple document on how to configure Flexconnect:
- https://supportforums.cisco.com/document/98646/wireless-lan-flexconnect-configuration-example
- http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-6/configuration-guide/b_cg76/b_cg76_chapter_010001000.html
PS: Please don't forget to rate and mark as correct answer if this answered your question
08-30-2016 11:01 AM
thank you again for your patience for a wireless newbie, supportlan.
Today I have tested a Flex Connect WLAN with my WLC 2504 a Cisco 3750 switch and a 1832 AP.
I have followed all the instructions of your documents and by now it is not working perfectly.
Please let me show you me issue:
These are my WLANs, I have selected SEK-JCR-L and SEK-JCR-S for Flexconnect WLANs:
Enable Flex Connect for both WLANs:
Enable FlexConnect for the AP:
Native VLAN 50, everything is working fine:
WLAN-VLAN 51, WLAN-VLAN 52:
Everthing is working fine again, I can connect to both WLANs with a Wireless Client and get IP addresses from the cisco switch!
But now the problem: If I restart the AP it changes to "Flexconnect Switching to Standalone Mode!"
[*08/30/2016 17:06:52.1956] Failed to get ARP entry for WLC 10.0.250.250
[*08/30/2016 17:06:59.8032] Failed to get ARP entry for WLC 10.0.250.250
[*08/30/2016 17:07:07.4108] Failed to get ARP entry for WLC 10.0.250.250
[*08/30/2016 17:07:15.0084] Failed to get ARP entry for WLC 10.0.250.250
[*08/30/2016 17:07:20.3168] Flexconnect Switching to Standalone Mode!
[*08/30/2016 17:07:20.3168] CAPWAP State: DTLS Teardown
[*08/30/2016 17:07:25.0653] Got WLC settings(10.0.251.250) from DHCP.
[*08/30/2016 17:07:25.0753] Discovery Request sent to 10.0.250.250 with discoverAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*08/30/2016 17:07:25.0853] Discovery Request sent to 10.0.251.250 with discoverAPWAP_DISCOVERY_TYPE_DHCP(2)
[*08/30/2016 17:07:25.0853] Discovery Request sent to 255.255.255.255 with discoo CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*08/30/2016 17:07:34.5723] Got WLC settings(10.0.251.250) from DHCP.
[*08/30/2016 17:07:34.5723] Discovery Request sent to 10.0.250.250 with discoverAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*08/30/2016 17:07:34.5723] Discovery Request sent to 10.0.251.250 with discoverAPWAP_DISCOVERY_TYPE_DHCP(2)
[*08/30/2016 17:07:34.5823] Discovery Request sent to 255.255.255.255 with discoo CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*08/30/2016 17:07:44.0793] Got WLC settings(10.0.251.250) from DHCP.
[*08/30/2016 17:07:44.0893] Discovery Request sent to 10.0.250.250 with discoverAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
[*08/30/2016 17:07:44.0893] Discovery Request sent to 10.0.251.250 with discoverAPWAP_DISCOVERY_TYPE_DHCP(2)
[*08/30/2016 17:07:44.0993] Discovery Request sent to 255.255.255.255 with discoo CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
And can´t find the controller again.
This is my switch config:
AP is connected to fa 1/0/11 and controller is connected to fa 1/0/23.
hostname SWITCH_SEK-JCR
ip dhcp pool AP-Netz
network 192.168.50.0 255.255.255.0
domain-name ITC-School
option 43 hex f104.0a00.fbfa
default-router 192.168.50.254
option 60 ascii "Cisco AP c1830"
ip dhcp pool SEK-JCR-L
network 192.168.51.0 255.255.255.0
default-router 192.168.51.254
ip dhcp pool SEK-JCR-S
network 192.168.52.0 255.255.255.0
default-router 192.168.52.254
interface FastEthernet1/0/1
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
switchport access vlan 50
switchport mode access
interface FastEthernet1/0/11
description AP Port
switchport trunk native vlan 50
switchport trunk allowed vlan 51,52
switchport mode trunk
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
spanning-tree portfast
interface FastEthernet1/0/24
switchport access vlan 250
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
interface Vlan50
ip address 192.168.50.254 255.255.255.0
interface Vlan51
ip address 192.168.51.254 255.255.255.0
interface Vlan52
ip address 192.168.52.254 255.255.255.0
interface Vlan250
ip address 10.0.250.254 255.255.255.0
interface Vlan251
ip address 10.0.251.254 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
What did I do wrong? Any idea?
Best regards!
08-30-2016 04:11 PM
what is your wlc IP address? Because AP wants to reach out 10.0.250.250 and in your option 43 you set 10.0.251.250.
08-30-2016 10:52 PM
Hi, it is working with this option. My mistake was, that I forgot the vlan 50 in the trunk to AP!
Now it seems to work. Thank you.
description AP Port
switchport trunk allowed vlan 50,51,52
08-31-2016 04:36 AM
Nice to hear that
PS: Please don't forget to rate and mark as correct answer if this solved your issue
