Please review/help WPA config
ttoney
Beginner
Beginner
It seems to be setup ok for 802.1x with WEP re-keying but we are not being assigned an IP address after connection is established. We have confirmed EAP-TLS works through our Radius box using a different AP, the Linksys WRT54G so it seems to be a configuration issue.
We need to setup:
802.1x with WEP Re-keying
802.1x with MD5 authentication. (We have the Radius remote access policy setup for this.)
WPA with 802.1X authentication, 802.1X re-keying
Cisco1200ap#show running-config
Building configuration...
Current configuration : 2390 bytes
version 12.2
no service pad
service password-encryption
hostname Cisco1200ap
enable secret 5
username xxxx password xxxx
ip subnet-zero
ip domain name bbn.com
ip name-server 192.168.2.200
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7
xxxxx transmit-key
encryption key 2 size 128bit 7
xxxxxxxx
encryption key 3 size 128bit 7
xxxxxx
encryption key 4 size 128bit 7
xxxxxx
encryption mode ciphers wep128
broadcast-key change 60
ssid tsunami
authentication open
authentication shared
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.2.3 255.255.255.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
radius-server local
nas 192.168.2.200 key 7 02040655
radius-server host 192.168.2.200 auth-port 1812 acct-port 1646 key 7 xxxxxxxx
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
1 REPLY 1
Not applicable
