We have a 5508 that has just been upgraded from 7.0.240 to 7.6.100 with many 1142's, 3502's, etc. Our wired network is HP 5406zl's POE on every port and plenty of power available for POE.
As soon as we upgraded our 1142's to 7.6.100 we started getting poe faults on several switchports. The trap indicates an over-current error and the AP will not power up. I can move that same AP to another switch port and some times that will work. If I reboot the switch the faults may clear on those ports, but will reappear on other ports. It is not always the same APs, and not always the same switch ports.
I have tried downgrading back to 7.0 and the errors clear. Obviously I want to be running the newer code for the bug fixes and features. TAC has not given this case any time yet.
The switches report more than enough power being available still on the ports. I can see the ports try to come up, and most of the times the AP will start to power up and come up at 8 watts as it boots, and as soon as the AP is ready to go and starts powering the radios it enters the fault state.
The APs all run in local mode, and I have tried enabling "Pre-standard 802.3af switches. "
Does anyone have any ideas? Something must have changed in the way power is drawn or negotiated.
HI Glenn,
Go for 7.4.121.0 (7.4MR2) version & see if this issue is there ? If not then it may be a bug/issue specific to this latest code. Here is the release notes for this code
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74mr02.html
Also makesure your WLC FUS also upgraded to 1.7.0.0. See below & keep note this will take 30-40min downtime to your wireless.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/fus_rn_1_7_0_0.html
The version I have given is the one most people including TAC would recommend
Rasika
**** Pls rate all useful responses ****
#Disable cdp and try.
#It is possible HP switch may not be allocating requested power by AP.
#involve HP TAC, run lldp debugs for verification.
