Point to Point Ad-Hoc "bridge"
Steven Juras
We have a soft opportunity to troubleshoot / redesign an existing wireless setup that from the start sounds a bit odd.
The customer has two desktop PCs with Cisco PCI Wireless NICs in them that are each connected to a 13.5 dBi Yagi antenna externally mounted (via a 50-foot Low Loss antenna cable). The two locations are approx. 1000' apart with we're hoping a good Line of Sight (LOS).
The customer states that the wireless link fails frequently enough to be a problem - meaning a few times a week. Both PCs have to be rebooted for the link to re-establish. We'll evaluate clear LOS and RF LOS.
My question is if anyone else has seen a deployment like this between two "long distance" PCs with wireless client adapters. Our initial reaction is to make this a true bridge link with two bridges, and network the 2 PCs that way.
Thoughts / Suggestions?
carenas123
Level 5
Level 5
It's not common to have set up like the one you are asking about. I would suggest you to have a relook at the device pool for conference resources
scottmac
Level 10
Level 10
Do you know what OS and / or software they're running on the PCs?
If they're doing something (stupid) like Windows XP and bridging the Wired/Wireless NICs, I'd tend to look more at the OS (patches, updates ...)
If they're running something like a Linux box and Zebra .... or some software bridge I think I'd still start with the OS ...
It could be something like a bird nesting on their Yagis, someone walking in front of their antennas (how high are they? On the roof or aimed out a window?)
Is this just the two PCs, or are they acting as bridges for two LAN segments?
If it's been working for a while, and just recently started getting flakey, and the antennas are outdoors, I believe the connections / connectors on the antenna would be a good place to start.
Checking for local interference would probably be a god idea too ... something like NetStumbler and see what channels are in-use.
It could just be a lot of things .... once you get a good look at it let us know what you find and maybe we can figure it out.
Good Luck
Scott
