08-05-2003 09:13 AM - edited 07-04-2021 08:55 AM
Dear all:
i want to connect two sites by wireless network , how can i connect them and what the best device i have to use , the distance between two sites is 7km , its a flat area , there is no brorders between two sites
08-05-2003 10:39 AM
I would recommend using , Cisco Air-350 Series bridges along with approx 13.5 dbi directional antenna to make a stable point to point link, the antennas could be used from a good local vendors since that will enable a host of choices at comptetitive price.
08-09-2003 06:09 PM
Just remember if you do use 3rd party anttenna's that are NOT certified to be used with Cisco Bridges then under part 9 of the FCC regulations it is up to the installer to certify that the system is compliant as you have modifed the system that Cisco had certifed
