Port configuration on WLC2006 and WLC2106
lldemeyer
In the WLC config guide V4.0 there is a clear explanation on how to use multiple distribution ports on the WLC440X. Is there also a similar sound description of how you can use multiple distribution ports on the WLC2006 and WLC2106 ? Somewhere in the Cisco doc I read that you can attach AP's directly to the 2006 distribution ports . If this is the case do you need to assign a unique AP-mgr address to each port to which you attach an AP?
0 Replies 0
