Hi all!!
I have around 110 2802I AP´s that need to be sended to remote locations.
Here is what i planned for each of them:
1. Via a dhcp server assign it an ip and join it to a 5520 WLC.
2. Let it upgrade the image software, and enable FLEX Connect.
3. Connect to the AP through CLI, change the given dhcp ip for a static ip in a different subnet(remote site subnet).
4. Send it to remote location were the port of the switch that the ap will be connected to is configured as trunk.
5. Connect the ap and do the rest of configuration through the WLC.
I assume this is possible or there is any caveat?
Thanks for Your reply!!
