Prime 3.10.3 Wrong 6-Mhz-Filter in 2.4GHz-map
Gehrig_W
Hello Cisco Prime Freaks,
I would like to filter on WLAN APs in maps using 2.4GHz.
But Prime is always starting with a wrong filter-statement of 6Ghz-radio on 2.4GHz-map:
Unfortunately I cannot delete the wrong filter argument.
I tried in vain already several Browsers.
Therefore the results is always empty.
Seems like a bug or ?
Please check and correct.
Kind regards
Wini
6 Replies 6
Hi @Gehrig_W
What if you remove the filter I highlighted?
Gehrig_W
Hello Flavio,
I cannot see thebutton to remove the filter statement.
Only valid choices are "Add rule" and "GO"
The existing fields are greyed and cannot be edited.
Kind regards
Wini
The filter I highlighted is greyed but if you rover the mouse over it, it become blue and you can select the frequency.
What I noticed in a Prime 3.10..2, is that if I select 2.4Ghz on that filter, the information I will see on the right side is related to 6Ghz, probably this is a bug.
But, if I select 5Ghz it show correctly and if I select  "2.4Ghz & 5Ghz" is also show correctly.
Hello Flavio,
so You can also confirm that this is a bug:
That is exactly my problem.
Background:
I want to filter all WLAN-APs using 2.4GHz-antenna to check FRA-settings.
But I cannot change the predefined "6-GHz"-Filter statement appearing on the right side:
This is a clear bug and should be corrected.
Kind regards
Wini
It will only be corrected if reported to TAC and they open a bug for it though so if you want it fixed be sure to open a TAC case.  Someone else may already have reported it in which case TAC will advise the bug ID and when (if) it is expected to be fixed.
