08-18-2021 03:38 PM
This might be in the wrong location.
I am replacing a failed Hard Drive on a Prime Infrastructure Appliance (Gen 2). Is there a set of instructions on how to proceed with this replacement?
Solved! Go to Solution.
08-18-2021 04:25 PM
I could be wrong but it is as simple as remove the faulty HDD and insert replacement.
Ask TAC what the correct replacement process is.
08-18-2021 04:25 PM
