Prime Infrastructure Upgrade - Running HA Prime as Active while upgrading Primary Prime
Scott Gillies
Level 3
Level 3
Is it possible to set a Secondary HA Prime as the Active prime while upgrading the Primary Prime?
This is to allow access to the Maps while upgrading the Primary Prime before upgrading the Secondary.
Thanks in advance
Rasika Nayanajith
You have to break HA prior to the upgrade. So I do not think you can use secondary as primary while doing the upgrade
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-7/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_7_0_Quick_Start_Guide.html
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
