Prime infratructure NCS 1.2 CSCOlumos/bin/wcsadmin error
Vincent Duprez
Beginner
Beginner
                   Dear all,
After a successfull installation of NCS 1.2 into a vmware environment and run the setup I have the following error while trying to start or to have a status for NCS (ncs start ot ncs status):
sh: /opt/CSCOlumos/bin/wcsadmin.sh No such file or directory
any idea please ?
Vincent
11 Replies 11
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
From the CLI, issue a NCS Status
Is everything else running?
Try to restart the service and then see or else reboot the VM.
-Scott
While doing the ncs status command I'm receiving also the "sh: /opt/CSCOlumos/bin/wcsadmin.sh No such file or directory " error message.
server has been restarted . I can logging and ping it but looks like th eapplication is not correctly installed:
For example a sh application provide:
and that's all.
For information:  I have reproduced twice this issue and after checking my VMWARE server ( a test one ) I noticed that it was overloaded...
By freeing some ressources on the esx server and running the setup one more time it solves the problem..
FYI: I haven't received  any error message during the previous installation except some warning regarding latency on disks
Yeah that will do it also. PI does require its resources or else it will error out or just be slow as heck:)
-Scott
Vincent,
Scott is right..
NCS/PI is very resource intensive. Please make sure the recommeded resources are made available for the VM as per the deployment size. Otherwise, the JVM within PI won't be start the neccessary components.
Ram.
dapmillan
Beginner
Beginner
Hi, i have the same problem but im not on a VM enviroment, i have the cisco appliance. Any idea???
Diego.
My solution:
I had the same issue. The reason for that error is not insufficient disk space, but a small disk size. If you install it on a 100 Gigabyte volume for example, the install process simply interupts, and you end up with the empty volume (try "DIR"command - the disk will be empty).
Try to Install it on a 350 Gb  volume, i believe that this is the minimum Disk requirement.
dapmillan
Beginner
Beginner
This is the output that i have.
PRIME-SERVER/admin# NCS status
sh: /opt/CSCOlumos/bin/wcsadmin.sh: No such file or directory
PRIME-SERVER/admin# show application status NCS
% Application NCS is not installed
PRIME-SERVER/admin#
Diego.
Vincent Duprez
Beginner
Beginner
Hi Diego ,
IS it a New install? In this case why not 1.3?
Can you check the disk space if it has already work?
Vincent
Hi vincent!.. Thanks for your answer.
About the 1.3 version im afraid my licences wont work since i have them for the 1.2 version. Shoul i be worried about that??
How can i check the disk space and what should be its state for the appliance works fine??
Thanks again.
Diego.
The same license should work fine. You may use "show disks" command to check the space.
Jatin Katyal
- Do rate helpful posts -
~Jatin
Recognize Your Peers
