Problem discovred 1815i to WLCV
Dhikra Marghli
Level 5
Level 5
Hello
i have Cisco Virtual Wireless Controller with version 8.9.111.0  and i have 13  acces point 1815i cisco
but the problem    that only access point 1815i is not discovred by wlcV      and all 13 AP  are same version 8.5.140  .
so   wlcV can dicover 12 AP but only this AP1815I  is not disovred
so i send two output  and i wait from expert wireless a reply and solution for this AP1815I  that is not discovred !!!
switch 2960
otsw-RDC#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
SRST_Tunis Fas 0/27 127 R S I 2811 Fas 0/0
ap Fas 0/14 123 T I AIR-LAP11 Fas 0
AP045F.B97A.3C08 Fas 0/25 157 R T AIR-AP181 Gig 0
Switch-federateur
Fas 0/22 157 R S I WS-C3550- Fas 0/16
AP4 Fas 0/47 120 R T AIR-AP181 Gig 0
AP8 Fas 0/23 132 R T AIR-AP181 Gig 0
SEP64AE0C5F90D8 Fas 0/21 144 H P M IP Phone Port 1
SEP64AE0C5E93A0 Fas 0/6 142 H P M IP Phone Port 1
SEP00270DBDE81D Fas 0/1 126 H P M IP Phone Port 1
SEPE84040A202B3 Fas 0/46 164 H P M IP Phone Port 1
SEP20370617DCAF Fas 0/5 129 H P M IP Phone Port 1
SEPFCFBFB1035CE Fas 0/18 153 H P M IP Phone Port 1
SEP203706174FF7 Fas 0/35 134 H P M IP Phone Port 1
R-Conferencing Fas 0/13 178 R S I ISR4331/K Gig 0/0/0
SEP20BBC092B566 Fas 0/20 148 H P M IP Phone Port 1
SEP40F4ECEEA877 Fas 0/45 144 H P M IP Phone Port 1
sotsw-RDC#show running-config interface fastEthernet 0/25
Building configuration...
Current configuration : 135 bytes
interface FastEthernet0/25
switchport access vlan 30
switchport mode access
switchport voice vlan 10
spanning-tree portfast
end
I send two pictures  : switch 2960 that AP link with port f0/25 with vlan 30
                                     second picture:  output wlcV :  AP045F.B97A.3C08
thanks in adv
Scott Fella
Console into the ap and reboot the ap. Post the output in a text file so we can see what the issue is.
-Scott
Scott Fella
-Scott
@scot
the problem appeared on the cable side: bad cable because I'm trying to connect the AP 1815i  directly to the switch 2960
the controller see this AP ...!!  so we try to replace the cable
thanks to reply me
Leo Laohoo
The attached files do not contain any useful information.
Like what @Scott Fella requested, console into the offending AP and reboot.  Post the entire boot-up process.
NOTE:  Duplicate threads of the same issue may be removed.
