Problem to Register AP2800 in WLC 8.3.143.0
Hello all, we have a problem with register the AP 2800 into the WLC 8.3.143 the status of the ap is blinking Cycling through Red-Off-Green-Off-Blue-Off we see the ap connected into the switch via cdp.
message:  Access point location command invoked from controller web interface.
Thanks for you help.
patoberli
Can you attach a console cable to the AP and reboot it and show us the output?
It might not get enough power, make sure your Switch supports PoE+ (802.3at).
patoberli
