Problem upgrading AIR-AP2802I
The_Switch_Cat
Hey everyone,
I'm having a problem with this AP.
At the moment it's running version 8.3.102.0 Mobility express and i want to upgrade it to version 8.5....
the problem is that with the current version on the AP there is no room to put the new version:
Filesystem Size    Used    Available Use% Mounted on
flash          57.5M 39.2M 15.3M      72%  /storage
normally this would be no problem as you can overwrite the previous version when using archive download-sw, but there is no /overwrite attribute to be found in the cli:
AP001#archive
download-sw Software Download commands
AP001#archive download-sw
/no-reload No-reload after loading
/reload Reload after loading
AP001#archive download-sw /reload
WORD TFTP transfer command
Does anybody know how to overwrite the previous version or just a way to get the 8.5 version on the AP?
Sandeep Choudhary
Its not easy but convert the AP to a CAP and then convert back to 8.5 Mobility Express.
Same issue here : https://supportforums.cisco.com/t5/getting-started-with-wireless/cisco-ap-3802e-upgrading-to-last-image-8-3-20/td-p/2956835
Dont forget to rate helpful posts
