Problem with roamingin in VoIP SSID...
Petar Petrov
Hi guys,
My client has a WLC 5508 with a two dosens  of 1262s. I set SSID for the VoIP but when the client roams there is a  loss of packest. The client is using Cisco phones. Any help will be  appreciated.
Pete
__________________________________________
(Cisco Controller) >show wlan 144
WLAN Identifier.................................. 144
Profile Name..................................... VoIP_Network
Network Name (SSID).............................. Inside_144
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 10
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ 144_v
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Platinum
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Disabled
      WPA2 (RSN IE).............................. Disabled
        Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-Air mode....................... Enabled
      FT Over-The-Ds mode........................ Enabled
      GTK Randomization.......................... Enabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
  WAN Metrics configuration
    Link status.................................. 0
    Link symmetry................................ 0
    Downlink speed............................... 0
    Uplink speed................................. 0
Mobility Services Advertisement Protocol....... Disabled
_____________________________________________
(Cisco Controller) >debug client 2c:54:2d:ea:d4:0e
*apfMsConnTask_2: Nov 30 17:02:25.463: 2c:54:2d:ea:d4:0e Association received from mobile on AP 34:bd:c8:b2:b1:10
*apfMsConnTask_2:  Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Changing  IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller  apf_policy.c:1697)
*apfMsConnTask_2: Nov 30 17:02:25.464:  2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Changing IPv6 ACL 'none' (ACL ID  255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1864)
*apfMsConnTask_2:  Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e Applying site-specific Local  Bridging override for station 2c:54:2d:ea:d4:0e - vapId 144, site  'Floor_1', interface '144_v'
*apfMsConnTask_2: Nov 30  17:02:25.464: 2c:54:2d:ea:d4:0e Applying Local Bridging Interface Policy  for station 2c:54:2d:ea:d4:0e - vlan 144, interface id 12, interface  '144_v'
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e  Applying site-specific override for station 2c:54:2d:ea:d4:0e - vapId  144, site 'Floor_1', interface '144_v'
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e STA - rates (4): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e Processing WPA IE type 221, length 22 for mobile 2c:54:2d:ea:d4:0e
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e apfMsRunStateDec
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e apfMs1xStateDec
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_2: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 START (0) Initializing policy
*apfMsConnTask_2:  Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 START (0) Change  state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_2:  Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 AUTHCHECK (2)  Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 Removed NPU entry.
*apfMsConnTask_2:  Nov 30 17:02:25.464: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3) DHCP  required on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2for this client
*apfMsConnTask_2:  Nov 30 17:02:25.465: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3)  Plumbed mobile LWAPP rule on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2
*apfMsConnTask_2:  Nov 30 17:02:25.465: 2c:54:2d:ea:d4:0e apfPemAddUser2  (apf_policy.c:268) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Associated to Associated
*apfMsConnTask_2: Nov 30 17:02:25.465: 2c:54:2d:ea:d4:0e Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_2:  Nov 30 17:02:25.465: 2c:54:2d:ea:d4:0e Sending Assoc Response to  station on BSSID 34:bd:c8:b2:b1:10 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_2:  Nov 30 17:02:25.465: 2c:54:2d:ea:d4:0e apfProcessAssocReq  (apf_80211.c:6290) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Associated to Associated
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Creating a PKC PMKID Cache entry for station 2c:54:2d:ea:d4:0e (RSN 0)
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Setting active key cache index 0 ---> 8
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Setting active key cache index 8 ---> 0
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Initiating WPA PSK to mobile 2c:54:2d:ea:d4:0e
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e dot1x - moving mobile 2c:54:2d:ea:d4:0e into Force Auth state
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Skipping EAP-Success to mobile 2c:54:2d:ea:d4:0e
*dot1xMsgTask:  Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Starting key exchange to mobile  2c:54:2d:ea:d4:0e, data packets will be dropped
*dot1xMsgTask: Nov 30 17:02:25.466: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_6: Nov 30 17:02:25.990: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:25.990: 2c:54:2d:ea:d4:0e Received EAPOL-key in PTK_START  state (message 2) from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:02:25.990: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:02:25.990: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
        state PTKINITNEGOTIATING (message 3), replay counter  00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.015: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.015: 2c:54:2d:ea:d4:0e Received EAPOL-key in  PTKINITNEGOTIATING state (message 4) from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e apfMs1xStateInc
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3)  Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  DHCP required on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2for this client
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  Plumbed mobile LWAPP rule on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e apfMsRunStateInc
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.016: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Reached PLUMBFASTPATH: from line 5362
*Dot1x: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 34:bd:c8:b2:b1:10, slot 0, interface = 1, QOS = 2
  IPv4 ACL ID = 255, IPv6 ACL ID = 2
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Fast Path  rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  Local Bridging  Vlan = 144, Local Bridging intf id = 12
*Dot1x_NW_MsgTask_6: Nov  30 17:02:26.017: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Successfully  plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e Key exchange done, data packets  from mobile 2c:54:2d:ea:d4:0e should be forwarded shortly
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
        state PTKINITDONE (message 5 - group), replay counter  00.00.00.00.00.00.00.02
*spamApTask5: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e Sent EAPOL-Key M5 for mobile 2c:54:2d:ea:d4:0e
*pemReceiveTask: Nov 30 17:02:26.017: 2c:54:2d:ea:d4:0e 10.123.201.4 Added NPU entry of type 1, dtlFlags 0x0
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.036: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:02:26.036: 2c:54:2d:ea:d4:0e Received EAPOL-key in  REKEYNEGOTIATING state (message 6) from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:02:26.036: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*apfMsConnTask_2: Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e Association received from mobile on AP 34:bd:c8:b2:b1:10
*apfMsConnTask_2:  Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Changing  IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller  apf_policy.c:1697)
*apfMsConnTask_2: Nov 30 17:03:17.385:  2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Changing IPv6 ACL 'none' (ACL ID  255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1864)
*apfMsConnTask_2:  Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e Applying site-specific Local  Bridging override for station 2c:54:2d:ea:d4:0e - vapId 144, site  'Floor_1', interface '144_v'
*apfMsConnTask_2: Nov 30  17:03:17.385: 2c:54:2d:ea:d4:0e Applying Local Bridging Interface Policy  for station 2c:54:2d:ea:d4:0e - vlan 144, interface id 12, interface  '144_v'
*apfMsConnTask_2: Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e  Applying site-specific override for station 2c:54:2d:ea:d4:0e - vapId  144, site 'Floor_1', interface '144_v'
*apfMsConnTask_2: Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_2: Nov 30 17:03:17.385: 2c:54:2d:ea:d4:0e processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e STA - rates (4): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e Processing WPA IE type 221, length 22 for mobile 2c:54:2d:ea:d4:0e
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e apfMsRunStateDec
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e apfMs1xStateDec
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 START (0) Initializing policy
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 START (0) Change  state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 AUTHCHECK (2)  Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 Removed NPU entry.
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3) DHCP  required on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2for this client
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3)  Plumbed mobile LWAPP rule on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e apfPemAddUser2  (apf_policy.c:268) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Associated to Associated
*apfMsConnTask_2: Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e Sending Assoc Response to  station on BSSID 34:bd:c8:b2:b1:10 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_2:  Nov 30 17:03:17.386: 2c:54:2d:ea:d4:0e apfProcessAssocReq  (apf_80211.c:6290) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Associated to Associated
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Creating a PKC PMKID Cache entry for station 2c:54:2d:ea:d4:0e (RSN 0)
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Setting active key cache index 0 ---> 8
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Setting active key cache index 8 ---> 0
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Initiating WPA PSK to mobile 2c:54:2d:ea:d4:0e
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e dot1x - moving mobile 2c:54:2d:ea:d4:0e into Force Auth state
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Skipping EAP-Success to mobile 2c:54:2d:ea:d4:0e
*dot1xMsgTask:  Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Starting key exchange to mobile  2c:54:2d:ea:d4:0e, data packets will be dropped
*dot1xMsgTask: Nov 30 17:03:17.389: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.422: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.422: 2c:54:2d:ea:d4:0e Received EAPOL-key in PTK_START  state (message 2) from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.422: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.423: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e Received EAPOL-key in  PTKINITNEGOTIATING state (message 4) from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e apfMs1xStateInc
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e 10.123.201.4 8021X_REQD (3)  Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  DHCP required on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2for this client
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  Plumbed mobile LWAPP rule on AP 34:bd:c8:b2:b1:10 vapId 144 apVapId 2
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e apfMsRunStateInc
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.433: 2c:54:2d:ea:d4:0e 10.123.201.4 L2AUTHCOMPLETE (4)  Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Reached PLUMBFASTPATH: from line 5362
*Dot1x: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Fast Path  rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  Local Bridging  Vlan = 144, Local Bridging intf id = 12
*Dot1x_NW_MsgTask_6: Nov  30 17:03:17.435: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Successfully  plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6:  Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e Key exchange done, data packets  from mobile 2c:54:2d:ea:d4:0e should be forwarded shortly
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e Sending EAPOL-Key Message to mobile 2c:54:2d:ea:d4:0e
*spamApTask5: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e Sent EAPOL-Key M5 for mobile 2c:54:2d:ea:d4:0e
*pemReceiveTask: Nov 30 17:03:17.435: 2c:54:2d:ea:d4:0e 10.123.201.4 Added NPU entry of type 1, dtlFlags 0x0
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.447: 2c:54:2d:ea:d4:0e Received EAPOL-Key from mobile 2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.447: 2c:54:2d:ea:d4:0e  Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile  2c:54:2d:ea:d4:0e
*Dot1x_NW_MsgTask_6: Nov 30 17:03:17.447: 2c:54:2d:ea:d4:0e Stopping retransmission timer for mobile 2c:54:2d:ea:d4:0e
*emWeb: Nov 30 17:03:46.162:  Configuring IPv6 ACL for WLAN:144, aclName passed is NULL
*apfReceiveTask:  Nov 30 17:03:46.173: 2c:54:2d:ea:d4:0e apfSendDisAssocMsgDebug  (apf_80211.c:2162) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Associated to Disassociated
*apfReceiveTask:  Nov 30 17:03:46.178: 2c:54:2d:ea:d4:0e Sent Disassociate to mobile on  AP 34:bd:c8:b2:b1:10-0 (reason 1, caller apf_ms.c:5558)
*apfReceiveTask:  Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e Sent Deauthenticate to mobile on  BSSID 34:bd:c8:b2:b1:10 slot 0(caller apf_ms.c:5678)
*apfReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e apfMsAssoStateDec
*apfReceiveTask:  Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e apfMsExpireMobileStation  (apf_ms.c:5716) Changing state for mobile 2c:54:2d:ea:d4:0e on AP  34:bd:c8:b2:b1:10 from Disassociated to Idle
*apfReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask:  Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e 10.123.201.4 RUN (20) Deleted  mobile LWAPP rule on AP [34:bd:c8:b2:b1:10]
*pemReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e 10.123.201.4 Removed NPU entry.
*apfReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e apfMsRunStateDec
*apfReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e apfMs1xStateDec
*apfReceiveTask: Nov 30 17:03:46.183: 2c:54:2d:ea:d4:0e Deleting mobile on AP 34:bd:c8:b2:b1:10(0)
16 Replies 16
I have tryed it...
test SSID with Open authentication and no encription - the same thing , the roaming is not smooth.
Our network architect was insisting that we do not need QOS on the LAN. What do you guys think ...?
George Stefanick
I would confirm coverage. Are your aps within range for proper roaming ?
Have you pulled a syslog from the phone ?
QoS could be a play.
