em 04-09-2015 02:00 PM
Olá,
Tenho o seguinte cenário.
Configurei 3 vlans no meu access point (Cisco 2602)
VLAN 254 Nativa
VLAN 11 Administrativa
VLAN 31 Visitantes
No switch eu fiz a seguinte configuração na porta:
interface GigabitEthernet1/0/44
description **AP**
switchport trunk native vlan 254
switchport trunk allowed vlan 254,11,31
switchport mode trunk
spanning-tree portfast trunk
O meu problema é o seguinte, eu não consigo pingar os gateways das VLANS 11 e 31 somente a vlan nativa.
Já revisei todas as configs do AP e nada me parece fora do normal.
Alguém consegue ajudar?
Segue config do AP
BT-SP-AP01#sh run
Building configuration...
Current configuration : 6034 bytes
! Last configuration change at 23:59:17 GMT Tue Mar 2 1993 by topazio
version 15.2
no service pad
service password-encryption
hostname BT-SP-AP01
logging rate-limit console 9
aaa new-model
aaa group server radius rad_eap
server 172.x.x.x
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
server 172.x.x.x
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
server 172.x.x.x
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default local group tacacs+
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone GMT -3 0
no ip cef
ip domain name x.x.x
dot11 syslog
dot11 vlan-name MGMT-TOPAZIO vlan 254
dot11 vlan-name VLAN_SP_ADMWLAN vlan 11
dot11 vlan-name VLAN_SP_VISWLAN vlan 31
dot11 vlan-name VLAN_SP_VOIPWLAN vlan 21
dot11 ssid TPZ-VISITANTES
vlan 31
authentication open
guest-mode
dot11 ssid TPZB-SP
vlan 11
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa version 2
ip ssh version 1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 11 mode ciphers aes-ccm tkip
encryption vlan 21 mode ciphers aes-ccm tkip
encryption vlan 31 mode ciphers aes-ccm tkip
encryption mode ciphers aes-ccm tkip
encryption vlan 254 mode ciphers aes-ccm tkip
ssid TPZ-VISITANTES
ssid TPZB-SP
antenna gain 0
stbc
station-role root
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 spanning-disabled
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
interface Dot11Radio0.31
encapsulation dot1Q 31
no ip route-cache
bridge-group 31
bridge-group 31 subscriber-loop-control
bridge-group 31 spanning-disabled
bridge-group 31 block-unknown-source
no bridge-group 31 source-learning
no bridge-group 31 unicast-flooding
interface Dot11Radio0.254
encapsulation dot1Q 254 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption mode ciphers tkip
ssid TPZ-VISITANTES
ssid TPZB-SP
antenna gain 0
no dfs band block
channel dfs
station-role root
interface Dot11Radio1.11
no ip route-cache
bridge-group 11
interface Dot11Radio1.31
no ip route-cache
bridge-group 31
interface Dot11Radio1.254
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.11
no ip route-cache
bridge-group 11
interface GigabitEthernet0.31
no ip route-cache
bridge-group 31
interface GigabitEthernet0.254
no ip route-cache
bridge-group 1
interface BVI1
ip address 172.29.239.252 255.255.255.0
no ip route-cache
ip default-gateway 172.29.239.1
no ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.29.x.x key 7 00363302556E18323F1B
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
password 7 0232544B2B1C5E717F7E
transport input ssh
line vty 5 15
exec-timeout 30 0
password 7 053F561F01561F592A35
transport input ssh
end
em 04-18-2015 04:25 PM
Essas vlans 11, 31 foram criadas no switch ?
em 05-28-2015 01:10 PM
De onde você está tentando pingar?
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
