Buenos dias
Tengo un problema con 2 Cisco Aironet Modelo 2602, el problema radica es que los 2 Cisco Aironet son Agentes DHCP, cuando intento conectarme a una Antena por medio de su SSID me conecto pero con una direccion IP que me entrega la otra Antena y viceversa.
La red es plana tiene un direccionamiento de
ap1#
no aaa new-model
no ip routing
dot11 syslog
username Cisco password 7 02250D480809
ip dhcp excluded-address 172.0.0.1 172.0.1.239
ip dhcp excluded-address 172.0.2.0 172.0.3.255
ip dhcp pool DATA
network 172.0.0.0 255.255.252.0
default-router 172.0.0.1
dns-server 172.0.0.16
bridge irb
dot11 ssid data
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 060506324F41584B56
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid data
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid data
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.0.0.57
no ip route-cache
ip default-gateway 172.0.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
ap1#
Antena 2
ap2#
no aaa new-model
no ip routing
dot11 syslog
ip dhcp excluded-address 172.0.0.1 172.0.0.220
ip dhcp excluded-address 172.0.1.0 172.0.3.255
ip dhcp pool DATA
default-router 172.0.0.10
bridge irb
dot11 ssid corp
authentication open
guest-mode
no ip address
no ip route-cache
ssid corp
antenna gain 0
station-role root
bridge-group 1
no ip address
no ip route-cache
ssid corp
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.0.0.19
no ip route-cache
ip default-gateway 172.0.0.10
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
ap2#
